# Maximum Reading Speed Check
> Ensure your captions are readable by controlling the words per minute.
URL: https://store.crowdin.com/maximum-reading-speed-check
Identifier: maximum-reading-speed-check
Category: Other
Type: QA Check
Author: Awesome Crowdin
## Maximum Reading Speed (WPM) Check
The Maximum Reading Speed (WPM) Check ensures that your translated captions remain readable by maintaining a controlled words per minute (WPM) count. This QA check is essential for video content, where viewers need to read captions comfortably without missing any information.
### Features
- **Time Difference Calculation**: Extracts start and end times from the context to compute the duration (Note: This check only works on the .srt files in your Crowdin projects).
- **WPM Calculation**: Measures the words per minute of the translation based on the duration.
- **Threshold Enforcement**: Compares the WPM to a predefined maximum threshold and flags captions that exceed this limit.
Note: You may need to adjust the WPM configuration of this check for non-Latin and Cyrillic alphabets. WPM is configured directly in the code of the QA check.
### Installation
To install this QA check, add the provided JavaScript code to your Crowdin project's QA checks. Customize the maximum WPM threshold as needed to suit your project's requirements.
Ensure your video captions are readable with the Maximum Reading Speed (WPM) Check, providing your audience with a comfortable viewing experience.
